S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Fixing suspension noise
Old Jul 28, 2010 | 11:56 AM
NihalS65's Avatar
1992 500SEL Black and grey 2 tone w/ camel brown interior
Lately my 92 500sel has been making a low pitched squeeking noise from the front right and both rear suspension. i took it to my tech and took a look underneath.
the control arm bushings are what the noise was coming from. all we did was take a hypodermic needle (can get them at any pharmacy store) and inject the rubber part of the bushings with oil. this will stop the noise for good. if the rubber is torn then you have to replace them. usually $20 a peice.
once you inject the bushings, bounce the car to check and make sure the noise is gone.
thats pretty much it! quick fix to an annoying problem. i learned this from my tech just today. he was named best mercedes mechanic in the midwest twice. pretty badass.
Old Jul 28, 2010 | 02:11 PM
oldsinner111's Avatar
s320
Secondary problem with that is oil eats rubber.A silicon based lube would work better.
Old Jul 28, 2010 | 02:59 PM
NihalS65's Avatar
awsome. ill make sure thats what he used.
Old Jul 29, 2010 | 04:26 PM
NihalS65's Avatar
the rubber on my rear bushings are torn and they not holding any lube. gonna change them out today.
