S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1995 S420 misfire - looking for coil replacement DIY
Old Sep 19, 2010 | 02:26 AM
last993's Avatar
03 ML500
Please, help.
95 s420 w/ 65,000 miles
Engine sputters idle, bad exhaust rotten egg smell
Did spark plus, rotors/distributors 5,000 miles ago
Suspect coil gone bad, where is it located at ?..did search w/ no luck
Your help/input would be much appreciated !
Old Sep 19, 2010 | 12:15 PM
deanyel's Avatar
400E
There's two coils, one for each distributor cap. They are down by the ABS pump, front/left of the engine compartment. Follow the coil wires from the distributor caps. But it's quite unlikely that you have a coil failure at that mileage, or double that mileage. Better to start by reading the fault codes on the 38 pin connector in the engine compartment.
Old Sep 19, 2010 | 03:43 PM
last993's Avatar
03 ML500
Thank you very much for the prompt reply, I found both of them this morning, one of them appears to be located in a place almost impossible to get to w/o removing the headlight assembly
I unplugged each one from the distributor cap, then made an attempt to start the engine.
I managed to start the engine w/ only one plugged-in. It ran smoother w/ no power. I suspect the one that's gone bad is the one I couldn't start the engine w/ ?...it's the one located in a very hard place to access
Am I on the right path ?
Am I
Old Sep 19, 2010 | 11:13 PM
deanyel's Avatar
400E
Hard to say for sure. Could be a problem with a spark plug wire or two, or one of the coil wires. You can interchange the coils if you wish - they are the same except for the mounting schemes. I'd still start with the fault codes. Your car has one of the all time great DIY fault code reading systems. Can you just remove the back cover of the headlight?
Old Sep 21, 2010 | 11:12 PM
last993's Avatar
03 ML500
Thank you, I will try to pull out the code over this weekend
