S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
help with making the car rise in the rear help 1998 s500
Old Oct 2, 2010 | 12:21 AM
basil,a's Avatar
just came from a e430 1999 to a s500 1998 just got the car look at and i need someone to tell me how i can get the car to rise in th back
Old Oct 2, 2010 | 06:33 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
The way the system works is, there is a tandem mounted pump with the power steering pump. There is hydraulic fluid from the fender mounted reservoir which is sent to a valve on the rear axle housing, the fluid is then sent to a accumulator (sphere which is filled with nitrogen) which is also in line with the hydraulic strut (shock look alike) as the valve opens oil is sent to the strut, the valve is hooked up to the rear torsion bar. There are possible issues, bad accumulators where the diaphram has failed, a defective valve, or a bad strut (very rare). or a bad pump (vary rare). The arm to the vave is adjustable.
