S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
SOS! 97 s320 something is wrong with ignition switch!!!!
Old Oct 15, 2010 | 09:25 PM
meren's Avatar
W104 S500 Coupe
Help, I'm stock. I cant turn my ignition, a 97 S320. I turn the key and it will not turn to a start position. It feels like something is holding it inside. I can lock and unlock steering wheel but no further. I tried switching gears in to N same thing. P to N no go. It feels like my ignition switch is frozen or something I should try before spending $$$$$$$$$$$$$$$$$$$ on this problem. THANKS.
Old Oct 16, 2010 | 01:57 AM
benica's Avatar
1998 and 2002 SL 500, 2014 E550 Convertible
Try this....
while turning the key to start the engine.....use one hand and rotate the steering wheel back and forth....it could be that it's in the lock position and it needs help to unlock it.....
if not...you need to replace the ignition switch....or you might have an electrical problem....not enough power in the battery, starter going bad, etc...
Old Oct 16, 2010 | 08:33 AM
meren's Avatar
W104 S500 Coupe
Thanks, but the only thing I can do is to lock and unlock steering wheel. I will not turn
further than that. It's like something is holding the key from turning all they way to start position.
Old Oct 16, 2010 | 09:16 AM
oldsinner111's Avatar
s320
I just replaced steering lock,tumbler,and electrical switch on my W126. It is worth the money to me next time,to tow to a independant,or dealer.Hardest job I every done.
