water leak 96 s 500
water leak 96 s 500
Seems like a simple detection process,but when the car is running the anti freeze starts to leak from the top hose connected to the engine.Replaced clamp,the hose is ok no cracks,does not overheat,there is little heat in pass. comp.
There seems to be something creating more pressure than normal.Im able to fix it, if I knew where to look.Anyone?
