S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Window Problems
Old Dec 1, 2010 | 06:07 PM
Nj Chuck's Avatar
95 s320
Window Problems
Driver side front and pasenger side rear window wont go down. Are the two windows somehow related? What could the problem be.
Old Dec 9, 2010 | 01:08 PM
philip29's Avatar
1995 s500
it could be the switches need to be cleaned , or it could be a relay ,or the motors are bad.. can you roll the back window down from the backwindow switch..
Old Dec 9, 2010 | 05:08 PM
oldsinner111's Avatar
s320
I have read where the rivets on the regulators pop off and cause trouble.
Old Dec 11, 2010 | 07:09 PM
Nj Chuck's Avatar
95 s320
windows
Its not the motors or the buttons. I already replaced the motor and it didnt work. Where would i find the relays. Also, its not the buttons because i found the wire that controls the window, and i applied direct power from the battery to the wire and it worked. I think it can be a short in the wire. What do you think.
Old Feb 19, 2011 | 04:14 PM
TAR's Avatar
TAR
"05 CLK320
Check out the fuses! Back in the day, I know that in the W126 chassis wiring schematic, the LF window and the RR window were protected by the same fuse. RF window and LR window were likewise on the same fuse.
Old Feb 20, 2011 | 12:11 PM
Nj Chuck's Avatar
95 s320
thanks, i checked the fuses, all are good. since my last post, the mirrors, power seats, AND windows stopped working. Can that be the comfort control mod?
Old Aug 3, 2011 | 01:53 AM
Weygand's Avatar
1996 S320
Does your SRS light come on?
/Go Giants!
