S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Ignition coil boot
Old Apr 6, 2011 | 08:27 PM
Descente36's Avatar
S320 97
Ignition coil boot
hey guys, i was wondering how to remove an ignition coil boot on a straight 6 97' s320. I figured the coil boot should pop right out so i tried yanking it out and the brittle plastic cracked, so now i got a stub where the ignition coil boot is and i have no way of getting it out.
Old Apr 6, 2011 | 11:39 PM
philip29's Avatar
1995 s500
so the ignition coil is stuck down in the shaft after you broke off the top of it , is that right . if so have you tryed some needle nose pliers to pull it out..
Old Apr 6, 2011 | 11:41 PM
Descente36's Avatar
S320 97
i tried using pliers but the chunks of the boot just keep comin off as i use force
Old Apr 7, 2011 | 02:51 AM
philip29's Avatar
1995 s500
have you tried a piece of a clothes hanger , something long and skinny , to wedge down in there and pull up the pieces.
