car shaking when engine is warm
i have this problem ,when my engine is warm like driving after 20 minutes my car shakes/vibrates a little when stopping at traffic lights or accelerating at low speed , but when i put the gear in parking the vibration stops.
is it something with my engine mounts or transmission fluid which i suspect.
w140 sel 600 1992
i saw a vacuum hose at the back on the engine that went to the intake that was a bit loose and i grabbed it at where it was plugged into and the vibration suddenly stopped
and my cars vacuum doors also sometimes doesnt work maybe its the because its losing pressure there.
i will replace those vacuum hoses and let you guys now !!
those rubber hoses were each 80 euros !!! nothing special just some rubber hose with a 90 degree corner and it doesnt have even pressure on it
replaced some vacuum hoses and the spark plug cabels(sooo expensive,and even expensiveer to replace it because it is so much work due the intake manifold that has to be taken of)
the vibration is completely gone and the car accelerates as the beast now
