S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Noob question: Antenna goes up when ingnition....
Old Jun 11, 2012 | 11:26 AM
Marcelito's Avatar
1996 S500
.....is turned on and stay up until ignition is turned off. Should it go up and down with radio instead?
I did not see this as much of a problem until I pulled up to the carwash, over the week end.
Any advice will be greatly appreciated. Car is a 1996 S500 Coupe.
Old Jun 20, 2012 | 12:28 PM
PelicanParts.com's Avatar
SPONSOR
Answer
My best guess is that someone has replaced the factory radio and/or CD player.
It is common for these alterations to screw up the antenna function.
FYI:
https://mbworld.org/forums/mercedes-...r-we-need.html
roy@pelicanparts.com
Old Jul 9, 2012 | 02:41 PM
Marcelito's Avatar
1996 S500
Thanks for replying Roy. I finally got around to reading the owner's manual , where it clearly states that turning off telephone would keep antenna from going up at ignition. Next challenge was to find telephone's "Off" swicth; it is on the receiver. This problem is solved. Next, onto my power passenger seat.
Last edited by Marcelito; Jul 9, 2012 at 02:42 PM. Reason: deletion of repeated words
