S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
tranny problem
Old Jun 14, 2012 | 11:38 PM
ronsaun's Avatar
1999 s500 w140
tranny problem
I think it's a bad night in the neighborhood, I went to Arbys and i was in the drive thru,all of a sudden it felt like the something was holding the rear in it was hard to pull forward,I got my food and she wouldn't move forward or backwards so i turned it off and waited 5 when i started up she pulled off very slow i pulled into a parking slot and there she sits,I never had a tranny act this way before could it be blown that quick with just the pull in the rear and no other signs.I know I don't know like you guys know so did you ever heard of this or has it ever happen to you is the tranny gone or is it something else I hope.thank you for your time
Old Jun 15, 2012 | 06:40 AM
oldsinner111's Avatar
s320
if it is a 98-99 disconnect battery,to reset the trans computer.They do wreid things.Try that if not working could it be parking brake?Rear ends (Diff) generally don't fail unless bad maint. habits
Old Jun 15, 2012 | 09:26 PM
ronsaun's Avatar
1999 s500 w140
first of all thanks for your reply,I tried it no got my friend got the following codes
013 speed sensor n3 43/611
065 control module n/3 15
109 speed sensor n3 y3/611
116 tr oil temp sensor start
120
121
132 ecm cam
147 gear implacsiable or trans sliping
161 control module
any body know what kind of trouble i got on my hands all comments welcome thanks guys
