S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Rear Window Regulator
Old Jul 10, 2012 | 07:11 AM
jdf2nd's Avatar
2011 E350 4matic, 1982 380SL
I need to replace the rear Window regulator on my 97 S420. Can someone give me instructions on how to do this?
Old Jul 12, 2012 | 08:40 AM
oldsinner111's Avatar
s320
I'm having mine fixed at a shop,you need special tool to remove panels
Old Jul 13, 2012 | 08:39 AM
jdf2nd's Avatar
thanks
Old Mar 21, 2013 | 06:18 PM
Grands600's Avatar
1996 s600
Window regulator
You do not need special tools, just patience. I just didboth rears on my 96. Order them online, they r about 50 bucks. The hard part is removing the wood panel behind the handle to get to the screws. Search here or on benzworld for rear door removal. To get the regulator out you will need to drill out 5 rivets. Replacing the regulator will require riveting the regulator back in or using nut/bolts. I ordered new rivets when I ordered my regulators and learned how to use a rivet tool. Overall it's not too bad, the first time takes about 1-2 hrs, I can remove the door in 10 min now. Good luck, it's definitely doable.
Grand
