S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
M119 S500 Poor Performance at low RPM
Old Dec 27, 2012 | 11:55 PM
number_one_c55's Avatar
2017 G63
Question M119 S500 Poor Performance at low RPM
Anyone have any idea's, checked codes no codes. When I first bought the car it had the spark plugs, distributor caps, rotors and cam seals replaced and the car hauled like a freight train. The other day, I decided to give it full throttle away from a stop and the car still pulled but was noticeably slower than my first experience. I noticed, if I keep the car in second or third gear and accelerate from 1500-6000RPM I can feel a HUGE power surge around 3000-3500 RPM anything above that RPM it reminds me of when I first bought it. The car also seems to produce lots of intake noise when hard acceleration below 3000RPM like the engine is chugging or not getting enough air, that being said ive had the air filters out and checked them and they are clean as can be......any one have any ideas??????????:conf used:
Old Dec 28, 2012 | 07:09 AM
oldsinner111's Avatar
s320
you might check the following,fuel filter,intake hoses not put together right,check catalytic convertor.check electrical connections.
Old Dec 29, 2012 | 03:22 AM
johnny conkaroo's Avatar
97 s420
if its sporadic and inconsistent accelerating it could be coil packs.
Old Dec 29, 2012 | 07:23 PM
2017 G63
sorry, vehicle is a 1994 does not have coil packs, main ignition coil has been replaced as well.
Old Dec 29, 2012 | 07:28 PM
97 s420
wow didnt know that. when did they start using coil packs 96? i only got 3 out of 8 good coil packs, my car seems to have surges of power in the worst possible moments.
Old Jan 1, 2013 | 02:49 PM
97 s420
how many times do i have to make u look like a clown. tonight when im with ur mother im gonna bust my nut on ur bunk bed ya *****
Old Jan 3, 2013 | 08:38 PM
eddie a's Avatar
94 S420,95 S500 ,96 S500
Must be the coil packs?
Old Jan 4, 2013 | 08:07 PM
2017 G63
Checked codes with DAS, code in ME for hot wire mass air flow sensor - will replace this next.
Old Aug 29, 2014 | 06:03 AM
InNeedOfSpeed's Avatar
S500L -96
I am having the exact same problem. Did replacing the sensor help? I've got the -96 S500L and it really needs the low end torque that it is supposed to have!
My mother has the -96 SL500 with the same engine and hers have mountains of torque at the low end!
Old Sep 28, 2014 | 03:43 PM
2017 G63
Hello, sorry for very late reply. I cleaned my MAF unit with MAF specific cleaner. It helped my vehicle but still wasnt 100%. Keep in mind that M119 engines are notorious for distributor caps, cam seals and plugs going back. Check these as well!
Hope this helps!
Old Sep 28, 2014 | 03:52 PM
S500L -96
Hope this helps!
Alright
Yeah the first thing I did after buying the car was new distributor caps and rotors, they were completely destroyed.
I cleaned my MAF with break cleaner, I think it's pretty close to MAF cleaner. It might have helped a bit but definitely not completely.
Not sure if plugs are likely since it works brilliantly at higher rpm, but maybe. (I've had it up to 260 km/h on the speedo)
Might try buying a new MAF even tho they are hella expensive... Was going to swap for the one in my moms SL500 but it turns out it's a couple months newer and has the plastic one while i have the metal one
Old Sep 28, 2014 | 03:59 PM
2017 G63
Hello,
If your mothers vehicle is equipped with M119 engine. Please swap MAF sensors from vehicle to vehicle. If problem still persists you will have further diagnosis to do. I would recommend taking vehicle to dealer to have fault codes printed out.
Old Sep 28, 2014 | 04:31 PM
S500L -96
Hello,
Yeah I would swap but I can't. Hers is different, two sensors in a plastic tube. Mine is aluminium and only has one combined sensor :/
Old Sep 28, 2014 | 05:24 PM
2017 G63
Hello, your mothers vehicle is equipped with a M113 not a M119 engine.
Old Sep 28, 2014 | 05:35 PM
S500L -96
Nah it's a 1996 SL500. They changed the MAF and some other stuff like 1996-06 i think. Same time they changed to the 5-speed transmission. Mine's a 4-speed, hers is a 5-speed.
