S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1995 S420 engine problems at 80 deg C
Old Jan 21, 2013 | 07:47 PM
Mokenney's Avatar
1995 s420
Having trouble with the 1995 s420. It will start fine and run great until it the engine temp gauge hits 80 c. After that when accelerating the engine sputters, and eventually stalls out. It will not start after that unless I let it sit over night. I can usually go about 8 miles or so before it happens. I have changed the distributor caps and rotors, plugs, wires. I took it to my mercedes mech and he had it for a week and a half and couldn't diagnose because it wouldn't throw any codes when it acts up. He said he did a vacuum test and it was good. What it throwing me off is it only acts up after it hits a certain temperature. Before that it runs fantastic. Any thoughts?
Old Jan 22, 2013 | 08:24 AM
oldsinner111's Avatar
s320
1 check wiring harness,and all connections
Old Jan 23, 2013 | 07:09 PM
eddie a's Avatar
94 S420,95 S500 ,96 S500
Could be your ignition control module ( EZL) When they heat up they fail..have you checked the codes?
