S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Problem with wipers (interval mode) - combination switch / relay / Wiper relay
Old Jan 27, 2013 | 09:35 AM
ifyita's Avatar
S600 W140
hi,
I have a 1995 S600 W140. I have problems with the wipers. Nothing happens when I turn combination switch to position I (interval). When measuring the signal input to the N10 (combination relay) N10: 1.1 I get (for positions 0, I, II, III on the combination switch): 0, 0, 12, 0 V. That looks to be in order.
However on the N10: 1.11 (interval/fast wipe mode) I get: 0, 11,98, 0, 12 V. According to the information on for example ALLDATA electrical diagrams I would expect <6 V on the interval mode (switch in position I).
I did measure the resistance as well and I found (for the positions 0, I, II, III on the combination switch): inf., 1789 Ohms, inf., 0 Ohms.
Do you think the combination switch is not working or could it be the wiper relay (K26) or the combination relay (N10)?????? It seems strange that I get almost same reading on the input to terminal 1:11 on the N10 when I position the combination switch in interval mode (I) and fast mode (III).
Just recently I also had problems with the wiper not stopping when I moved the combination switch to 0, wipers just kept swiping.... However, right now they stop in correct position both when combination switch is in 0 or I (interval).
I could tell you that the car has not been used recently (for about a year) due to another problem, and these problems appeared when I started to use the car again. The car has been parked outdoor in Sweden (very cold in winter).
Old Aug 21, 2013 | 09:35 AM
aldedmon's Avatar
500e
Solution??
Did you ever figure this out
