S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
problems with my 95' S500 need help
Old Feb 18, 2013 | 10:55 AM
robert123's Avatar
Ml320
I recently bought a 95' s500 got it with only 140xxx miles and runs great. The car sat for a while before I found it so it had some rubber rot to deal with and only two small rust areas to be repaired. As I was racing around this weekend trying to get the cars gas tank flushed ect. I sprung a coolant leak. It is trowing coolant from the driver side cowl area. I started to remove the cabins fresh air box because the leak seems to be under their somewhere?
Does any one have an idea of just where I should lookm for ther leak or maybe know where the leak is coming from and could tell me where to look? Can I fix the leak with hand tools in the drive way? Any help would be appriciated, thank you
Old Feb 18, 2013 | 01:17 PM
oldsinner111's Avatar
s320
try plastic tee on fire wall
Old Feb 18, 2013 | 01:52 PM
robert123's Avatar
Ml320
I'll give it a look thanx for the advice I'll let you know if it was the issue. Sweet looking S320
