S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
not acceleration on s 320 1999
Old May 15, 2013 | 09:58 PM
gatennispro's Avatar
1999 s 320
mecanic change oxigen sensor to fix engine light lamp warning. After changed car had not acceleration he reset codes and I drive car for two days fine now bas/sar lamp came out and pedal has not acceleration at all. anyone please help
Old May 17, 2013 | 05:18 AM
oldsinner111's Avatar
s320
did he use a oem sensor or generic? I think to reset light you turn wheel fast to right and left all the way.
Do me a favor would you look under you backseat at vacumm pump.Tell me the connector with 21 spaces for wires
the numbers start away from pump 1 thru 7 middle row 8 thru 14,and next to pump 15 thru 21. I need all colors and numbers wrote down,its to hard to see from photograph.Thank you.wish Eddie A could help us both.
