S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
oil
Old Sep 2, 2003 | 10:40 AM
solhood's Avatar
1994 Mercedes Benz S 500
oil
I had the oil changed on my 94 S500 125,000 recently and the mechanic told me they put in around 8 quarts of oil? Is this normal?
REH
Old Sep 2, 2003 | 02:48 PM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
Yeah, thats right. One quart per cylinder is roughly what it is. The car holds 8.5, and you should be putting in 8 quarts, or 8.5 as I did to get some extra for the filter (which you can't fill yourself). I used Mobil1 0w40 (euro car formula, same stuff the dealer uses) and it seemed to run a little smoother.
