S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
W140 AC center vent valves cycling
Old Jul 2, 2013 | 07:16 AM
1999 S500's Avatar
1999 S500 Grand Edition
I have a 1999 W140 S500 and when I accelerate, the center vent valves cycle closed and then open after a bit while operating the AC. The AC blows ice cold even in florida summer. Right now, it works otherwise but it is annoying. I can also feel the motor idling a little rough every now and again. I think that there it is a small vaccuum leak but I am not sure.
Anyone ever had this problem? Is this one of those $1000 labor for the $25 part things?
Thanks,
Mark
Old Jul 4, 2013 | 04:50 PM
1999 S500's Avatar
I tried doing the test but the '99 has a different set up. No left or right wheel to turn to the red or blue.
Old Jul 4, 2013 | 05:23 PM
1999 S500's Avatar
1999 S500 Grand Edition VIN: WDBGA51GXXA419433
It is digital with the Auto Buttons on each side.
Old Jul 4, 2013 | 09:43 PM
1999 S500's Avatar
OK,
Thanks for the info. I will take a look.
Old Jul 9, 2013 | 07:25 PM
1999 S500's Avatar
I got the car back today.
The motor does not provide vacuum. The AC Vents are worked with vaccum supplied by the PSE Pump under the back seat. The pump is providing the vacuum, but there was a leak in one of the lines going to the passenger front seat. I had them cap off the line and all is well again.
It is the rough equivalent of flipping the garbage disposal switch and the garage door opening. Go figure.
