S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
93 500 Dash lights blinking
Old Sep 10, 2003 | 07:08 AM
goltd@insightbb's Avatar
93 500 SEL
1993 500 SEl the dash lights sometimes flash when I use the right turn signal. And the right turn signal does not work properly.
MB says I need a new digital dash for $1000.00
Any ideas
Thanks, Jeff
Old Sep 10, 2003 | 01:32 PM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
Unless you do want to pay a grand, I'd just rip out the instrument board and check it for shorts and also the turn signal assembly. If all else fails, then you'd still have the pay the big bucks, or you could end up fixing it yourself if you find the problem
Old Sep 11, 2003 | 05:55 PM
Dano500's Avatar
S 500
Hi !
Change the Battery ! It doesn't look like dead, but the battery chage helps !
-Teemu aka Dano
