S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Kuehlbox
Old Dec 3, 2013 | 09:52 AM
DominicBelmah's Avatar
W140
Kuehlbox
I just came across a coolbox which I understand is meant for W140. This link gives you an idea of the particular product which I would like to install in my W140 (S320). http://www.w140forum.de/showthread.p...Limo-und-Coupe
The problem is the existing petrol tank does not have the cavity to see this through. I believe the W140 (S600) has a petrol tank with the cavity which allows the coolbox through to the armrest at the rear passenger seat. I am determined to search for this.
The question here is,
1. Can I fit the S600 petrol tank to my S320 without much damage to the existing body framework?
2. Can this coolbox fit into my car with the changed petrol tank in my car?
Your insight view and input is much appreciated. Cheers 3x!
Old Dec 7, 2013 | 05:06 AM
oldsinner111's Avatar
s320
for such a small cooler,I would not go to this trouble,there are several large coolers that will run on a lighter
Old Dec 7, 2013 | 07:13 AM
W140
Oldsinner111: Thank you. I live in Malaysia as such I may not be able to relate well to the large coolers that you have in mind. Can you kindly refer me to any links with an image of the bigger coolers so that I can have a feel of what those bigger coolers look like.
Thank you very much.
Old Dec 10, 2013 | 04:28 PM
s320
sorry can't post image they screwed this forum up to for pictures.I saw two at www.ebay.com search for 12 volt coolers
Old Dec 10, 2013 | 09:24 PM
W140
Thank you sir! Noted and have seen the coolers in ebay. I will keep a look out in here to see what is available. Next will figure out how I could actually fly or ship out one of this coolers from the states.
Merry Christmas and a Happy New Year!
