S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Problem in the system .ABS.. I want a solution
Old Dec 6, 2013 | 07:40 AM
alkerzarabi's Avatar
C320
Good morning car S 500 Model 1998 operates when the car is no problem .ABS. Lighting system does not work, but when the car is moving 30 feet ignites special lighting system .ABS. Please help in solving the problem, thank you
Old Dec 7, 2013 | 04:57 AM
oldsinner111's Avatar
s320
Check the relays to see if loose.Remove top of fuse panel under hood to reveal relays.They can be loose or need replacing
