S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
!! HELP-acute overcharging situation
Old Jul 5, 2014 | 03:27 PM
ryerdd's Avatar
w140 500SEC
Began as a flicker of battery warning light. 24 hrs later solid bat. ASR and ABS lights, limp mode , repeating noise under rear seats when key is in II position. 60 day old CC820 battery 12.9 volts measured 18volts when car is at idol. lights operational one head light blown 30 sec after switched on. Any suggestions on trouble shooting or best approach to component evaluation. literally a one moment everything fine. within 10 min everything not. appreciate any and all feed back. don't have a MB authorized budget so anything I couild do safely myself is cool/
1994 S 500 coupe. 112000 miles , wiring harness looks OK.
Old Jul 8, 2014 | 12:08 PM
MarcusF's Avatar
2002 CLK430
Sounds like a bad voltage regulator. A new Bosch regulator is less than $30 for your car.
