S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 Mercedes-Benz 300SE help!!
Old Sep 15, 2015 | 10:20 PM
j-quest's Avatar
300se 1992
Talking 1992 Mercedes-Benz 300SE help!!
hey guys hows it going, im thinking of getting a 1992 Mercedes-Benz 300SE for my first car, the guy wants to sell it for $2500 aus dollars and the car is in great condition. He was telling me that he thinks the car has only done 160,000 km but on the odometer it says it has done 340,000 but but he said it clocks 2 km for every 1km travelled on the car. and he told me that there is nothing wrong with the engine but some of the electronics need attention, he said "The knob that controls the rearview mirror and side mirrors needs fixing - only works through memory controls."
he also said "Driver and front Passenger window work fine but rear windows although working look like they need adjustments. The cluster dash works intermittently on oil gauge and clock and temp - you tap the screen and it corrects. Seems like something is not connected right."
and on top of that the aircon stopped working but i can buy a new compressor for that if thats all it needs.
im keen to learn about the car and do some services by myself, eg change the oils, replace the ac compressor etc
but is it worth getting for $2500-2000?
Old Sep 16, 2015 | 07:37 AM
dbldpr's Avatar
Veteran: Navy
Welcome If the odometer says 340 then it has 340 He basically told you since the car was new it has always doubled the mileage every time it has been driven. Very unlikely since the car when new was under warranty. If you buy it just be prepared to put a lot of money into it.
Old Sep 16, 2015 | 01:08 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Welcome to MBWorld. I'd be highly suspicious of his double kilo claim. Easy way to verify though is to take a test drive with him on a highway and see if his claims are valid though. Good luck.
Old Sep 17, 2015 | 06:16 PM
PelicanParts.com's Avatar
SPONSOR
Welcome to MBWorld!
Old Sep 18, 2015 | 01:32 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W140 forum...
Old Sep 21, 2015 | 03:46 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
I would have a Mercedes mechanic conduct a pre purchase inspection before I would purchase. As mentioned before the mileage is probably correct and the electronic gremlins are a warning sign. The air conditioning could be very costl to repair as the compressor may not be the root cause, search for air conditioning evaporator ssues with the w140 and you may want to select another car.
