Self Leveling, Can it be modified, Tricked out?
I have installed 20" Lorinser D93 wheels and H&R Lowering Springs, I have a nice tight look on the front but the rear was still up in the air. The rear springs were then cut a little bit and the car still remains high from the rear. Im wondering if there is any way to trick the height control to reduce the height which it is set at? Any ideas?
I'd like to thank you for your response to both my 1st (AC Issue) and 2nd post on the site. Abput the lowering question. Is this something I can do myself if I have my auto on a lift is it an adjustment to some sort of threaded rod? If so is there a guideline as to the ratio of adjustment as to the distance of drop? As always thanks for any info in advance.
The car should be sitting on its wheels, this is not an adjustment with the wheels hanging down, probably a little trial and error. If you remove the acumulators and Hydraulic shocks, you will encounter other issues because the systems looks for a little residual pressure for ride comfort
