S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
New member - 300 SD - need help removing door panel
Old Oct 3, 2016 | 07:33 PM
Ehennninger1's Avatar
1994 300SD
Hi All,
I'm a new owner of 1994 300 SD Mercedes. My first Mercedes and I love it. Car is in great shape inside and out(fully rebuilt engine ( 5k miles/ chassis has 180k). The only issue so far is my drivers side window came off its track. Window motor works well and I sprayed all windows mechanisms ( and rubber trims)with silicon based lube... Help the Windows mechanisms.
When I roll it up it leaves a small gap. I determined the window is not on the track...it has pick its own "rails" to move up.
I need to get at the window & track , but cannot find all the screws holding the door panel on. All you tube videos show door panel removal for different doors. Looking for advice or direction to get me a drawing of the panel to locate all the screws.
Many thanks for any help
Old Oct 5, 2016 | 10:48 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W140 forum...
