Mods to 95' S320?
its only an s320 with little torque so what can i do for speed?
next best mod would be a free flow remus exhaust, you have have to welded on to replace stock muffler. Not only will it free up alot of the back pressure (which is A LOT), but it will also save weight (probably a good 15-20lbs, maybe more). Also spare tire and jack removal should also help. hope that helps.
easy, intake is #1 mod you should to. I spend $25 on 9 inch K&N air filter and it must has added a good 10-15HP at the wheels. The biggest difference is the intake noise is much gruntier (almost V8 sounding) and there is so much more low end torque, as soon as you step on pedal it wants to go.
Have you dynoed your car to see if the 10-15 hp at the wheels from an air filter?
btw 10-15 HP at the wheels translates to 12-18HP at crank, not 20-25. just to clarify.
