S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Speedometer, Odometer not working plus ABS and ASR LIGHT ON
Old Mar 24, 2017 | 03:41 PM
John Doe15's Avatar
1995 S420
1995 s420 Speedometer, Odometer not working plus ABS and ASR LIGHT ON
Just need help figuring out what the issue is or get any suggestions on what it could be . Btw its a 95 s420
Old Mar 27, 2017 | 11:09 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Is the car in limp mode? Could be brake light switch, throttle actuators, etc. need more details before anyone van help...
Old Mar 27, 2017 | 11:28 AM
John Doe15's Avatar
1995 S420
Car runs fine , i recently changed both distributors and rotors . Thats how it was when i bought the car a few weeks ago . I checked all 3 fuse locations and all fuses seem to be fine .
Old Mar 28, 2017 | 06:58 AM
burgca's Avatar
Check the Brake light switch and the third brake light bulb, I did get these lights when the bulb died.
http://www.peachparts.com/shopforum/...ed-easily.html
Old Mar 28, 2017 | 10:14 PM
enthusednoob's Avatar
1999 S500
check the fuses first. i had same problem and changed my brake light switch and still got the dash lights. after that didn't work i THEN decided to check the fuses, and of course it was blown. so i turned a 5 minute fix into a couple hours + shipping time for the part, but hey lesson learned. and now I have a backup brake light switch
