S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
92 500SEL Pwr Steering Hose Leak
Old Apr 12, 2004 | 08:17 PM
MB_500's Avatar
92 500SEL
Can anyone help out with the Part Number of the High Pressure Hose that comes out (or goes to) the Power Steering box? I guess this is the same unit that feeds the Hydraulic suspension (load leveling?) system.
The leak (about 1 quart a month) appears to be seeping out of the front section of the hose assembly, where the threaded metal fitting is crimped onto the rubber hose. It's directly inboard of the driver's tire and slightly aft (behind) the pump reservoir.
I'm almost sure there's no repairing this item - it'll have to be replaced, but I can't bear the idea or the cost of taking it to a dealer. I'm sure we can replace the item for much less somewhere else.
Comments, suggestions?
Old Apr 13, 2004 | 11:56 AM
guydewdney's Avatar
which one?
5 is 140 466 01 81 (up to 95) or 140 466 12 81 (after 95)
11 is 140 997 48 82
20 is 140 997 35 82 (up to 95) or 140 997 86 82 (post 95)
23 is not applicable.
Old Apr 13, 2004 | 01:05 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
If you are looking for the high pressure line, it is #5 in the diagram that Guy so kindly posted, p/n: 140 466 01 81, about $118 from www.buymbparts.com.
Old Apr 13, 2004 | 04:49 PM
MB_500's Avatar
92 500SEL
you guys are the best!
The part is ordered, it'll be here in 2 days, and we'll have it R&R'd by this weekend. Hopefully, we'll also get the engine wire harness changed out, with the plugs.
Maybe the car will be ready to hit the road Sunday!
I can't thank you people enough, really. Especially Guy - you gave me the harness Part No. too, remember?
