S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
How do I replace the door/seat bulb?
Old May 2, 2004 | 01:39 PM
shmelvin's Avatar
none
My passenger door illumination for the seat controls has burned out, How do I get the door apart to replace the bulb?
Old May 2, 2004 | 05:43 PM
guydewdney's Avatar
assumign its nearly identical to the coupe...
open door
remove chrome panel on end of door (three top plate, 5 or 6 bottom plate
remove by pulling from top corner the leather triangle behind / inside of wing mirror
look inside door handle / grab arm, there is a small (1/2" long 1/3" wide) plug covering a large phillips screw. be careful when removing plug - use a small flat screwdriver.
under the arm rest (above) is a 1" diamert plug, rubber, pry out and remove large phillips screw deep inside
in door panel is a SRS badge - again, remove and inside is a phillps screw.
un pop from the bottom all the poppers holding card to door. gently!!! some WILL brake, they are not expensidve part number 007 988 99 78 ($14 for 20)
the next bit requires a bit of force, and guts. when the poppers are removed / loose (there are 20 of them!!) hold the card at about 5 to 10 degrees out, and pull up from the end of the door. there is a long springstrip running the length of the top of the door theis will un peel / spring off - IT IS TIGHT!
getting it back on is reverse - but note the plastic tongue about where the switches are that locates into a hole in the door.
hth
guy
oh - the bulb might well be 000 825 07 82...
