S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1995 S500 no reverse - is this common?
Old Dec 24, 2017 | 12:40 PM
SCT's Avatar
SCT
1995 S500 1968 280SL
I have a 1995 S500 - at about 97k the reverse simply stopped working, all other gears work. ONly option was to replace tranny, lack of money stored car for several years. Just had used tranny not rebuilt installed, less than 500 miles, same problem. Is this common this model? Car is otherwise excellent, 98,000 miles. Fix or will this keep happening?
Old Dec 25, 2017 | 05:36 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Not common if the transmission is serviced properly, what was the service history of the replacement trans?
Old Dec 25, 2017 | 06:11 AM
oldsinner111's Avatar
s320
mercedes trans give you a warning when reverse goes,to rebuild or replace trans.
