S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
What in the World is happening
Old Aug 27, 2018 | 05:37 PM
gwiz16's Avatar
95' S420
I have a 95' S-420. After starting, all of the tattle tail lights (warning lights) blink like a Christmas tree, and none of the needle gauges work! Sometimes the lights go out, and the gauges return to normal for a couple of seconds, then start back blinking again! Can someone please tell me what in the World is going on? Thanks
Old Aug 27, 2018 | 09:13 PM
gwiz16's Avatar
95' S420
Testing?
Originally Posted by Plutoe
Sounds like you have one or more bad grounds----start testing!
Where do I begin?
Old Aug 27, 2018 | 11:34 PM
gwiz16's Avatar
95' S420
Not a couch potato!
Get off the couch and search for the wiring diagrams for the systems you have problems with and look for the ground connections----it's not rocket science just time consuming and you don't want to pay someone so you do it yourself!
If I knew which system I was having a problem with, I would definitely search for the wiring diagram. I was doing my research by asking these simple questions I have asked, and though I don’t mind paying someone to fix the problem I don’t want to get taken for a ride if you know what I mean. But thanks for Your help anyway!
Old Aug 28, 2018 | 05:53 AM
oldsinner111's Avatar
s320
how's your engine wiring harness? check for breaks,in insulation.Sometimes batteries with a bad cell will cause this to.
Old Sep 3, 2018 | 09:26 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
The pre-96 W140 have issues with biodegradable upper and lower wiring harness, unsure how long you've had the car but this is a source of a multitude of issues. However, I agree with old sinner check battery voltage first since you already checked fuses. Electrical gremlins are not always easy to diagnose but start small fuse, battery, wiring, and validate voltage. Good luck
