S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
CHECK ENGINE ON - EVAP SYSTEM
Old Nov 11, 2018 | 08:31 PM
MEPEHcali's Avatar
CLK320
I need some helping trouble shooting my 1999 W140. It's been a long project for me and i replaced/fixed about 10 hours worth of parts on this car and seems like i'm close to getting it smogged (with your help)
Now I'm getting the following errors:
P1453 Air Pump Relay - Replaced 2 different ones - same error
P1420 Air Pump Switch over valve - replaced with a working one - same error
P0466 Activated Charcoal Canister Valve - No idea how/where to troubleshoot
P0443 Purge Control Valve - No idea how/where to troubleshoot
I tried supplying +12V directly to the Air Pump and i can hear it working without any weird sounds. Just like the other MB i have.
It just seems like this whole EVAP system is not getting any power or the ground terminal is not connected (don't know where to check)
I have also supplied power directly to the Air Pump relay and it should in theory turn the Pump on, but nothing happens.
I have replaced all the vacuum lines around the engine and replaced gas cap.
Only at he end of the day today, my Alternator Light came on (with the SRS light as well). It does go away when i rev it over 2000rpm
Could those errors be related to a low voltage issue ?
I plan on replacing the Alternator tomorrow and see if anything changes.
Does anyone have any other suggestions?
Old Nov 11, 2018 | 08:40 PM
MEPEHcali's Avatar
CLK320
Here's the beauty I'm trying to save from the salvage yard - 220k miles
