S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
AC blower "driver side" not blowing hot air
Old Jan 13, 2019 | 02:06 PM
Francis Florita's Avatar
1996 S320
I have a 96 s320 and the driver side won't change from cold to hot air but the passenger side works fine. Any idea what part I have to check and/or replace?
Old Jan 13, 2019 | 08:47 PM
1996 S320
Originally Posted by Plutoe
post your VIN!
WDBGA32E3TA321839
Old Jan 14, 2019 | 09:41 PM
1996 S320
Sounds to me that you have an AC flap issue-----you can use your AC control unit to do the flap test------then you can go to the switchover valve block and vacuum test the corresponding vacuum flap actuator which would be faulty---other than that see a good old MB AC mechanic as the older ones are very complicated!----if you are looking for a simple fix---find a gypsy
thanks. I'll try the flap test
