S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1997 sl600 issues
Old Feb 16, 2019 | 03:49 PM
SUPERBOAT24's Avatar
SL600
1997 sl600 issues
My 1997 sl600 has engine code p0507, engine fluctuating between 800 to 1100 rpms, throttle bodies have vacuum, they are turning on and cleaned them, sprayed vacuum lines with water, no leaks. I can't seem to locate a IAC valve, any help would be appreciated
Also my roll bar and convertible top switches are on, roll bar is up and hard top is on. I reset the windows & roll bar, checked the pumps and fuses, don't, know what else to look at, thinking the convertible top module is bad, does that control the roll bar too!!!
Old Mar 1, 2019 | 11:29 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W140 forum...
