S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Removed air resistor from s500 grill. Helped a lot!
Old Jul 7, 2004 | 01:57 PM
s0vietbenz's Avatar
1995 w140 s500
Talking Removed air resistor from s500 grill. Helped a lot!
Yesterday I was trying to figure out how to get more air into the car. I picked up the hood and I see 2 air resistors behind the grill. so I close my hood I look it totally covered the intake's... I took it off and I felt a diffrence. So I tested it out with my freind who's car is always dead even with me 20-130. we never pull on each other since I got my chip and air filters... I went out for a run with him and I was 1/2 car ahead of him. I couldn't beleive my eyes. so I slowed down and we ran 3 more times and it was the same result all 3 times.... I was just amazed. The car breath's much better and it gets more power...
Old Jul 7, 2004 | 03:39 PM
snair11's Avatar
You did this on the 95 s500? What exactly did you remove, I want to try this.
Old Jul 9, 2004 | 01:27 AM
s0vietbenz's Avatar
1995 w140 s500
pull up ur hood and on the inside side of the grill there are two triangular plastic air "blockers" ... just take a flathead and pull them off ... there are just smalll clips holding them in ...
Old Jul 9, 2004 | 01:37 AM
snair11's Avatar
What do those thingies do exactly?
Old Jul 9, 2004 | 05:38 AM
guydewdney's Avatar
they are there to stop debris / water from entering the air intake - as baffles...
i dont condone this personally. nor the K&Ns (due to the MAS sensor problems associated with it....)
Old Jul 9, 2004 | 11:41 AM
s0vietbenz's Avatar
1995 w140 s500
guy but there is also an air resistor right next to the air intake....
Old Jul 9, 2004 | 11:42 AM
s0vietbenz's Avatar
1995 w140 s500
I haven't had a problem with it yet. as long you don't over oil the air filter it should be just fine.....
Old Jul 10, 2004 | 12:03 PM
ViKTORiOUS's Avatar
W209 - W163
Nice but its risky, you could really damage your engine from debris flying into your air intake and really futz things up, becareful.
Old Jul 12, 2004 | 10:22 AM
snik's Avatar
96 S500 Coupe
I don't think its risky at all... any debris will be stopped by the airfilters anyway... In addition, there is a mesh above the filter on the airbox housing.
I took mine off as well, and it feels pretty quick at 120+ km/h. When I stepo on the "go fast woohoo" pedal, it feels like a much lighter car.
Certain cars are even manufactured this way,... TransAm WS6 with LS1 and ram air is designed from the factory to feed air directly to the filter where any debris would be stopped by the filter.
Old Jul 12, 2004 | 05:20 PM
s0vietbenz's Avatar
1995 w140 s500
snik did u cut out the other air resistor. I was thinking about it but not sure if I shoudld it. it blocks about 3/8 of the air intake. if u look straight ahead u can see it.
Old Jul 12, 2004 | 11:57 PM
snik's Avatar
96 S500 Coupe
you are talking about the shroud in front of a/c fans with 2 portrusions covering the inlet of air intake pipes right? I took off that whole shroud (4 fasteners), and put it in the trunk.. in the event it rains very heavily I will put in on (minus the fasteners), and when rain subsides I will remove it again.
Old Jul 13, 2004 | 02:45 PM
s0vietbenz's Avatar
1995 w140 s500
wait so if it rains you think I should put it back on?
Old Jul 14, 2004 | 02:54 AM
snik's Avatar
96 S500 Coupe
it would probably be a good idea to put it back on if it rains hard... for a slight drizzle I wouldn't worry about it too much
Old Jul 15, 2004 | 03:07 AM
Bernanke's Avatar
yup did this on the S320, helped alot
Old Jul 27, 2004 | 12:28 PM
s0vietbenz's Avatar
1995 w140 s500
it doesn't help alot it just gives it a bit of extra breathing room.
Old Jul 27, 2004 | 01:41 PM
s0vietbenz's Avatar
1995 w140 s500
I thought it was a lot. but I cant notice the diffrence anymore maybe I got usto it. but the car is a bit faster.
Old Jul 28, 2004 | 12:12 PM
SpeedLimits?'s Avatar
E320 CDI
i cant remember how things are laid out exactly on that engine however a cone style filter with a outerwears cover would allow you lots of air and no risk of water ingestion. outerwears are great prefilters that are splash proof, the dodge cummins diesel community (my other ride) and experimented with them a lot!
Old Jul 31, 2004 | 11:20 PM
s0vietbenz's Avatar
1995 w140 s500
is there any way I can fit cone filters into my w140 s500?
Old Aug 5, 2004 | 03:25 PM
Bernanke's Avatar
yes there is, they make 3 inch diameter cylinder type K&N air filters for cars with tight spots. running one on each bank would definately help alot, also the sound would be absolutely amazing. that plus air baffle removal would allow air to run directly to filter. a great mod in my opinion and its cheap to, only $35ish per filter.
