S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Ets malfunction
Old Jul 24, 2019 | 09:50 AM
Nicknate21's Avatar
E320
Ets malfunction
Hey guys and girls I got a 96 e320 and I have abs and ets lights coming up on dash and check engine too. I got a p0505 code on my obd2 code reader, which is idle malfunction. My cruise control doesn't work either which I know it switches off when abs is switched off due to a problem. Yesterday after work it started up fine and all my lights were there still but I took off and it wouldnt let me go over 20mph even with gas pedel pressed completely, like wouldn't idle high like it normally would. So I stopped and turned it off and held pedal a little and turned key on (heard this resets the idle air control) Which it did and I got it to work fine again, but the lights are still there and problem is still there. Any idea guys? To help is much appreciated!
Old Jul 24, 2019 | 11:14 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W140 forum...
