S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
New to MB
Old Aug 9, 2019 | 04:51 PM
Baldandy's Avatar
1999 S430
New to MB
Hi all
I’ve recently purchased a 1999 S430 which has been unused for the last 6 years. This has been converted to a 6 for Limousine.
I know...I should have seen the red flags!
Anyway, there are a few issues but one that is really bothering me is the fuel consumption. I know it’s never going to be an economical car but the “after start up” MPG is between 3-6mpg. The other reading is showing as 17mpg. Could it be that because the car hasn’t been used for such a long time that the engine isn’t running efficiently or is this a common problem.
Thanks in advance.
Last edited by Baldandy; Aug 9, 2019 at 05:11 PM. Reason: Think I started the thread on the wrong page
Old Aug 9, 2019 | 06:39 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the S430.
3-6mpg is not proper function.
Have you measured the actual fuel consumption by hand? Did you fill the gas tank completely full, then drive some miles, and see how much gas is needed to refill the tank completely?
Have you had the codes read? You need to collect some more information.
Old Aug 9, 2019 | 06:57 PM
Baldandy's Avatar
1999 S430
Hi
I’ve only filled it half full after buying it but can see that it’s already used over 1/4 of a tank and only done 25 miles. I’ve bought the car for business. It’s going to be a funeral Limousine.
I had a guy look over the car and he did send me a diagnostic report, but to be honest I really didn’t know what I was reading. He didn’t mention a fuel consumption issue in the layman’s report he sent to me. That said, he also didn’t tell me about the leak I must have in the front suspension either.
Do you know which code I should be looking for?
Old Aug 9, 2019 | 09:32 PM
chassis's Avatar
2017 GLE350 4MATIC
List any codes that are stored, and people here will be able to help you generate options.
Old Aug 10, 2019 | 12:54 AM
Baldandy's Avatar
1999 S430
Please excuse my ignorance as really not sure what to list from the report.
Below are all the CODES that have come up.
C1504-009
C1026-128
C1517-001
C1517-002
B1010-001
B1881
B1000
B1636
N1141
B1010
B1762
B1734
B1005
B1521-005
B1521-005
B1193-000
B1111-001
B1269
Old Aug 10, 2019 | 09:53 AM
chassis's Avatar
2017 GLE350 4MATIC
Replace all batteries first (starting and auxiliary if there is one), unless you know with 100% certainty they have been recently replaced and are fully charged. Then proceed.
Can you post photos of this vehicle? What wheels and tires are currently installed? What other modifications have been done, besides the 6 seat limousine conversion?
None of the codes you listed are related to engine or fuel. This seems strange. Several of the codes are consistent with low battery voltage, either now or in the past.
Have you given the vehicle a thorough visual inspection, from above, and from below? Are you capable of DIY mechanic work? It could be there is a mechanical problem in the fuel delivery (tank, pump, injectors) or exhaust system that is not generating a fault code. Have you had the vehicle tested for emissions? What does the exhaust smell like? If it smells like raw gasoline, there is a problem. If it smells "normal", look elsewhere. What does the engine sound like when idling? Smooth? Or lumbering and unstable? Do you hear any hissing or clicking or tapping? You need to do a lot of diagnostic work.
Some of your codes did were not listed in the resource below.
https://w220.ee/M-B_Fault_Error_Code...ble_Codes_(DTC)
C1504 BAS light, play in steering column causes steering angle sensor to lose memory(?)
C1026-128 Steering angle sensor is not initialized.
C1517-001 Critical vehicle level at front axle
C1517-002 Critical vehicle level at rear axle
B1000 HRA Headlamp range adjustment: Supply voltage of the control unit is too low (undervoltage)
B1636 The component or the signal line to the component E13/2 (Glove compartment illumination with switch) has Short circuit to ground.
Old Aug 10, 2019 | 10:37 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W140 forum...
