S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
ADS help! Light on light off
Old Jul 11, 2004 | 09:19 PM
Helga's Avatar
93 600SEL
I need help! The ADS light on muy 1993 600 SEL comes on while riding down the road. When I come to a stop I turn wheel hard left and hard right to recalibrate. Light stays on. I turn the car off and light goes off. A few minutes later it comes on. Is the angle sensor bad or is the connection loose.
Also, when the light comes on what default mode is it in? Comfort or sport.
Thanks for any help.
Old Jul 12, 2004 | 04:55 AM
Wintermute's Avatar
500SEC, ML430, SLK230, S600
The car should automatically disable ADS; thus, it will default to a mode that resembles "Sport." Unfortunately, your symptoms are too ambiguous to provide an absolute diagnosis. If you intend to continue driving the vehicle prior to servicing it, however, you should probably attempt to ensure that no hydraulic leaks exist. If they remain unchecked, such leaks can eventually cause additional problems that are somewhat "costly" to repair.
HTH!
Old Jul 12, 2004 | 10:05 PM
Helga's Avatar
93 600SEL
Wintermute,
Did once over on hyrdraulics and no leaks. Got codes, 3 and a 14. Code 3 is a body acceleration sensor and code 14 is steering angle sensor not initialized.
Question is two fold. Do these sensors go bad and does the sensor initialize before the steering sensor? Any ideas?
Old Jul 14, 2004 | 12:08 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
Sensors
Sensors do go bad, MB warns not to bang on any area where they are installed. They are mounted on the front steering knuckles, one on the left side of the engine compartment. There is also a load sensor that is in line with the leveling valve and the left rear pressure reservoier, they all send info to the ADS control unit.
The steering angle sensor must be initialized if it lost power or the battery was disconnected. The ignition must be on and the steering wheel turned from left lock to right lock (according to the notes)
Old Jul 15, 2004 | 10:00 AM
Helga's Avatar
93 600SEL
Peter,
Thanks for input. Body and wheel acceleration sensors $330.00 each, steering sensor $1300. I will be converting to standard shocks.
Helga
Old Aug 14, 2004 | 12:44 AM
MB AMG's Avatar
2002 E55 AMG
Weird, while bringing the car out to wash the ADS light came on. So I restarted it and it turned off??
Old Aug 14, 2004 | 03:24 PM
MB AMG's Avatar
2002 E55 AMG
Just found out the ADS is not working in the 600SEL. The suspension is as hard as a rock!!
