S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
50 mph, The Dreaded Vibration
Old Nov 13, 2019 | 03:41 PM
PaxPeter's Avatar
On my 1996 S500 Coupe, I've had the dreaded vibration, I haven't found a comprehensive list of issues to check so I'm trying to compile one of the things I should check with a mechanic friend.
Anything I should add to this list or caveats?
Also, is 150Nm the torque spec for the wheel bolts?
Draft list:
  1. Check all suspension bushings for damage (tie rods, upper/lower control arms, etc.,) - this is often from the lower control arm bushings but could be other components
  2. Check front and rear flexdisks - the front flex likely has worn out more
  3. Check the long “shaft mount” and “shaft bearing” - may be called the “center support bearing”
  4. Do not use airtools for installing bolts unless using a torque limiter/meter ... install bolts in torque sequence using a torque wrench
  5. Star crossed torquing is very critical because the stock rims have a very big center bore and lug bolt holes
  6. Tires might have flat spots from sitting
  7. Road force balance
(cross posting this)
