S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Wiring harnesses
Old Jan 1, 2020 | 06:15 PM
stuntflyr1's Avatar
1992 600 SEL & 1993 600SL
Wiring harnesses
Striking out on trying to find a engine harness for my "92" V12 for the MAF's, not the center one for the injectors. Any ideas besides rewiring it myself? I know Delphi makes replacements for some of them but can't locate this particular one.
Old Jan 1, 2020 | 09:09 PM
chassis's Avatar
2017 GLE350 4MATIC
deleted
Old Jan 1, 2020 | 09:18 PM
chassis's Avatar
2017 GLE350 4MATIC
Which one, if not the injector harness? What components does it interface with?
Not this one?
https://www.kurth-classics-autoparts...405404705.html
Old Jan 1, 2020 | 09:29 PM
stuntflyr1's Avatar
No, it is not that one. I've already replaced that one a few years ago. I need the one that goes to each of the Mass Airflow Sensors (it's the V12 engine) and to the electric vacuum solenoids. There are three 2 wire solenoids on the engine. Two on the right side and one on the left side of the engine. Solenoids are mounted on the sides of the intake manifold. So.... the harness consists of two round twist connectors, one round connector to each of the MAF's and 3 two wire plugs for the solenoids then the other end of the harness runs back to the computer box and plugs into one of the 6 boxes.
Old Jan 2, 2020 | 05:33 PM
stuntflyr1's Avatar
Cool Update....
After further extensive investigation, no such harness exists. The two MAF sensor plugs (p/n: A1405400081) are sold individually for about $130.00 each that have 6' of wire attached to them and have to be meticulously routed back to the ECU's in the "coffin" then soldered to the individual pins that the ECU's plug into. Ho hum......
Old Jan 2, 2020 | 08:35 PM
chassis's Avatar
2017 GLE350 4MATIC
Time to get the soldering tools out! Sounds like a project coming up for you stuntflyr1!
Old Jan 2, 2020 | 08:44 PM
stuntflyr1's Avatar
Yes Sir! I get to practice on my 600SEL first before I move 1 bay over to my 600SL!!! Had to peek at the SL this morning with my fingers crossed....I figured being only a year apart it would be wishful thinking....and it was....
Old Feb 18, 2020 | 11:30 AM
stuntflyr1's Avatar
Talking
On the road again! Runs perfectly! Quite the project though!
