S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S600 Alternator issue
Old Mar 11, 2020 | 03:34 PM
Zacman1's Avatar
67 250sl
1994 S600 Coupe. The original alternator needed to be replaced. MB Alt and Pulley is no longer available. I purchased a Bosch AL 0169 X which comes without the Pulley. When I installed it the pulley does not align with the other pulleys, causing the belt to climb the smog pump pulley, and trash the belt.Bought a second AL 0169 X and it is the same. The unit can't be bolted in wrong. The pulley can not be shimmed . Any ideas, anyone seen this, Thanks.
Old Feb 4, 2021 | 04:02 PM
uniballerbenz's Avatar
2008 E350
did you ever come up with a fix? im going through this right now
Old Feb 4, 2021 | 04:33 PM
Zacman1's Avatar
67 250sl
Yes, its a pita. I had to shave some material off the mounting ears, and add washers to space the alternator towards the radiator. been working fine for the last six months. File the ears a little at a time, use a micrometer to get the same thickness, test fit every so often and eyeball the alighnment to the air pump. It will work, but took a couple of hours. I could not find an 8 groove pulley that would work. Good Luck
