S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S600 A/C problem (on drivers side only)
Old Aug 31, 2004 | 11:42 PM
amgmercedes's Avatar
No matter what temp (even at max coldness) I set the driver's side climate control to, the driver's side vents blow out hot air. The passenger side works fine.
Fiddling and turning the climate control "wheel" will sometimes bring back the cold air, but after a while the hot air comes back again.
Does this mean the control unit needs to be replaced? Or is there something else I should check?
Thanks.
Old Sep 5, 2004 | 02:30 PM
JAM's Avatar
JAM
SL600
Sounds like a damper issue. Ironically, I am taking my SL600 in to the dealership for the same sort of issue.... The drivers side vent always blows hot air and the passenger side vent doesn't blow any air at all. I take the car in on 14Sep, so I'll let you know the diagnosis.
