S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
98 S420 Cranks but does not start after driving
Old Oct 25, 2021 | 06:44 PM
W140S420's Avatar
Mercedes S420 W140
I have a 1998 S420 W140, when I start the car in the morning it starts fine, but after I drive for a while and stop the car (turn engine off), the next time I try to start it, you have to crank the key a long time and push the gas pedal to make the car start. I've replaced the spark plugs already and all the fuses are working fine.
Any idea what could be the problem?
Hope someone can shed some light.
Thank you!
Old Nov 10, 2021 | 06:29 PM
HedonisticFrog's Avatar
1996 S420, 2001 SLK320
It's likely the crankshaft or camshaft position sensor. Are there any other symptoms besides that? Does the engine have to get warm before it will struggle to start again or can you start it multiple times in succession while it's cold?
Old Nov 10, 2021 | 08:43 PM
W140S420's Avatar
Mercedes S420 W140
This was fixed already. Took it to the dealer and fuel pressure regulator was replaced.
Old Nov 13, 2021 | 07:45 PM
Thanks for the update, I just realized that's likely the problem with my 96 S420 as well which was blowing clouds of white smoke on acceleration and also having trouble starting. The fuel pressure was high with and without vacuum.
Old Nov 17, 2021 | 11:39 PM
fabbrisd1's Avatar
A gaggle of MB's
If engine is Warm/Hot - and hard to restart - then "very-very" likely culprit is Crankshaft Position Sensor - CPS - replace ONLY with Genuine Bosch Sensor like $45 - on the install there is a little washer between the sensor and crankcase - you need to re-use that - as that washer does NOT come with the Bosch OE sensor. If your "smart" get that little washer from your MB Dealer Parts Dept BEFORE you go to replace that sensor. There is probably a YouTube out there on the job
