S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
W140 Blower Motor Replacement EASY
Old Nov 24, 2021 | 11:38 AM
Rlover's Avatar
1999 S420
Don’t replace just replace the resistor blower control. I got mine off Amazon for $27.00 and installed it and guess what? Yup the brandnew FPOS resistor control was junk. Before I had no blowing motor and now i had the pleasure of one speed and when I turned the car off the blower motor did not shut off! I had to disconnect the battery. The Dealer wanted over a $1k for this repair 🖕🖕🖕
you need a Phillips head screw driver, a #20Torx and about a 1/2 hour. ( if you did a 2nd Blower motor it would take you 5 minutes) Make sure you disconnect the battery. ( you will have to reprogram windows) Good opportunity to replace cabin filter.
