S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
How to rest the SRS light on W140?
Old Jan 23, 2022 | 12:14 AM
Search123@@'s Avatar
1998 S320 LWB
Please help. How can I rest the SRS light on W140?
Hi everyone!
I had to paint the steering wheel on my 1998 S320, so I disconnected the battery then removed the airbag and steering wheel, After the paint dried, I reinstalled everything making sure that the wires are connected and all. When I connected the battery, I noticed that the SRS light came and stayed on. Is this supposed to happen? How do I get the SRS light to turn off? Thank you.
Old Feb 20, 2022 | 09:13 AM
henboy1's Avatar
buy the code reader and reset.Most mebners here aint technicla so most of your post will remain unanswered.smh
Old Oct 12, 2022 | 04:34 PM
Gerson's Avatar
1992 300e-24
Originally Posted by Search123@@
Hi everyone!
Hi, How did you solve it ? It happened the same thing with my 97 S320 when I replaced the steering wheel. I have the obd1 code reader and used on 38 pin port but it didn’t show any fault codes stored on pin 30 (airbag system) so I can’t reset anything…
