Strange misfire without octane booster
https://youtu.be/JJXNjqWmaWk
Not only will they cause a misfire but also rough idling or difficulty starting the vehicle.
Another part to check (or just replace to be sure) is the crankshaft position sensor.
This was an issue on my 300SE and caused the same problems as you have described.
(Misfire when moving off or taking a long time to start, it will just keep cranking. Mine actually stalled on an intersection when trying to move.)
These are more difficult to test and may even produce normal readings at slow rpm, thats why I suggest replacing it.
