S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
97 s500 oil change
Old Oct 19, 2004 | 01:52 PM
bigswole's Avatar
97 s500
97 s500 oil change
I have a 97 s500 and is intersted in changing the oil myself. My brother has a 740il and we change his oil all the time. We got instructions off the e38 message board though. We are preety handy guys but we know German cars are engineered in a different way. Just posting this to see if there were any experts who know to chane the oil.
Thanks in advance for any help.
Old Oct 28, 2004 | 12:57 PM
joetucc's Avatar
1998 E300
not sure exactly for your car...but the oil filter should be located on the front of the engine on the driver's side. You will probably need the oil filter wrench from the dealer, about $20 bucks. The drain plug is underneith the car, you have to put it on jack stands to make it easier. Remeber to drain the oil when it is a operating temperature. Check the owner's manual for the correct amount of oil to add. My guess is about 8 quarts.
