The M104 requires head gasket replaced every so often. The dealer did mine for a couple thousand if I recall correctly (timing chain cover was updated as well). Another weak point is the heated windshield washer fluid reservoir. A "fuel line" size rubber hose carries coolant to the windshield washer tank on the front passenger side where the rubber I believe changes to aluminum "fuel line" size tubing in the reservoir, and comes back out to the engine via rubber hose. When mine leaked I just bypassed the reservoir. Good luck.
