S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Is the w140 reliable?
Old Jun 11, 2018 | 09:20 PM
Maxamillion's Avatar
Lincoln LS V8
Question Is the w140 reliable?
I am sure this question has been asked before, but how reliable are the w140s? I know there are some maintenance hurdles to jump, like the faulty vacuum pumps/vacuum lines, as well as bio-degradable wiring harness, and other things. I had also heard of a transmission issue? At some point I would love to acquire one of these beasts. What is the most reliable model? I definitely don't want the s600. So what are all the common issues? what should I look for? Are there voltage regulators on these cars? Thanks
Also side note, there is a two tone green over tan 400 sel that I know of. I know very little about the car, other than that it has been sitting for years. possibly a decade. it does appear to move every once in a while though. Would this seem like a good buy? Or does that sound like a total money pit. I looked at it once. It actually looked to be in pristine condition aside from a door panel being removed. I need to learn more about it first, though.
Old Jun 18, 2018 | 10:27 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Reliability will be based on the prior owners upkeep and maintenance as the W140 over 20 years old (okay 19 for the '99). If the prior owners have taken care of the car the first gen (prior to '96) would probably have had the wiring harness replaced which should not be an issue. First gen had power rear view mirror, rear telescoping rods for reverse and the sedans had better carpet and leather, and additional horsepower, and rotors (before coli packs). The later models include parktronic sensors, rain sensing windshield wipers, xenon lights, coil packs, and OBDII ports for limited DIY use, etc.
Arguments on message board
http://www.benzworld.org/forums/w140...ersus-v12.html
Old Jun 25, 2018 | 02:45 PM
oldsinner111's Avatar
s320
had mine since 2009, no problems.,thou i have a iron block six,easy to work on.
Old Jul 29, 2018 | 08:29 PM
deathdadder's Avatar
2005 CL55 AMG
if this is the same 400 SEL I was looking at on craigslist ('93 green over tan), it is very sus that he didn't put check engine is on and he probably needs a new throttle body or fuel pump
Old Jul 31, 2018 | 01:04 PM
s320
pre 96,have bad wiring,and sorry 4 speed trans,but better leather.
Old Aug 1, 2018 | 12:20 PM
burgca's Avatar
Curious on why the coupe leather improved after '96 with Nappa leather an eliminated the perforated leather
Old Jul 31, 2022 | 10:14 PM
DetoNateR's Avatar
1995 S320 SWB
mine is a 95, 5 speed 722.5 trans. Had bar harness but replaced both main engine harness and throttle body...left with the alternator harness but so far its not showing any signs of failure. Had my 95 s320 for almost 2 years now and i daily her with no probl3mo. Just came back from 11 hr non stop road trip from myrtle beach south carolina to NY. Avergaing 80mph no hiccups and full tank of gas made it all the way with 1 fill up. What a beast she is.
Old Aug 15, 2022 | 04:31 PM
bicylindrico's Avatar
They are some of the most expensive cars I repair in my shop. I don't see as many because of this reality
Old Sep 18, 2022 | 05:08 PM
JohnLane's Avatar
222 S-65
140 Cars were a consistent moneymaker back in the day. Lots of systems. Window regulators. Harnesses. Engine mounts. Suspension parts. Cooling system and A/C issues. That said.... I enjoyed my ‘96 140-120. That wonderful snarling bent-12, a Five speed transmission with brakes that were ohhhh too small.
Old Jan 30, 2024 | 12:32 PM
Mercedes300.'s Avatar
mercedes w140
w140
the best car ever, no probpems at all.
