1995 S320: Rear Passenger Vents
Lee
Vacuum is used to actuate flaps that direct air to the various ducts. Perhaps the flap for the heat to the rear isn't doing its thing.
Brett
If you are getting heated air out of the floor ducts the duo-valve is working. The 600 sedan and coupe have heat capability with an entire heater /ac core in the consloe which is individually controlled from the rear seat!
Recently I was waiting at a ferry terminal to return to Vancouver from Vancouver Island. It was a major rain storm, the window was fogged up as I had to wait 41/2 hr. for the ferry. When it was time to load I pushed the defrost button on the dash, I had never touched this button before. The heat that came out on to the winchield was blazing hot, there was no fooling arround, the window dried right off right now!
So I now realise the auto temperature control is there to keep you comfortable not hot/over heated.
